Dewesoft forums
Welcome back! Sign in. Search forums:
Forum home  >  DEWESoft software  >  heat release not show
Author Post
vafara
Posted on: 16.12.2008 at 00:01 AM
Login to reply or quote this post!
I use dewe-box-ca-education and dewesoft 6.6
I want to show heat release in overview in CA scope diagram and went export data the heat release and IMEP TQ TI is zero
And the Crank Angle in math menu I try to use Angle sensor I have but the sensor type is 60-2, 36-2 not show sensor Encoder -1800
Dewesoft Administrator
Posted on: 17.12.2008 at 06:50 AM
Hello,
I guess the first problem is related to Heat Release check box. You have to check heat release check box in CA->Thermodynamics so it will calculate heat release. Then you can see it in the CA Scope and you can export it.
To solve the second problem you have to set CA Math in Angle Domain (Sampling) and connect Encoder-1800 directly to counters.
vafara
Posted on: 18.12.2008 at 22:15 PM
my program it does not have Thermodynamics tab
but when I use DEMO mode it show this
and this is my setting
enable combustion analysis
when register complete the Thermodynamics and knock detect tab it doesn't appear as the first picture.
Posted on: 19.12.2008 at 01:49 AM
Hi again.
Thanks for providing detailed description about your problem. Unfortunately CA BASE license does not allow you to use Thermodynamics and Knock detection. You need CA-OPT1 license in order to use Thermodynamics. To acquire CA-OPT1 license please contact your local dealer to get more details.
You can check for your local dealer in where to buy section or check for the international dealers on Dewetron webpage. You can also contact worldwide sales office at this email: sales(at)dewetron(dot)com.
If you have any further question, just contact us again.
Your sincerely,
DEWESoft
Posted on: 19.12.2008 at 01:55 AM
One more thing. If you would like to try out Thermodynamics before you purchase your CA-OPT1 license you can use evaluation license, which will allow you to try full functionality of DEWESoft for limited time.
To generate your evaluation license, please login to our website and follow this link.
Hope this helps you.
Best regards,
DEWESoft
